Do you know this part?
I began my first-ever restoration -- a 37-610 code 125. And when I removed the chassis from the cabinet, this piece was jammed underneath. It appears to be plastic so I don't think it comes from the radio, but I just don't know. I think it's plastic because it appears to have melted beneath the chassis. I don't think bakelite ever gets misshapen like this, does it? This radio did have signs of having been repaired once in the past. The power cord was replaced with a modern cord. One of the rubber bushings that the chassis sits on inside the cabinet is missing and it appears this piece was jammed in there to keep the chassis from shifting. But all of this is mere speculation. I am a total novice at this. So anyone know what this is? My only concern is that it could come from the radio somehow.
[Image: http://www.jamesdavidporter.com/photo%201.JPG]
[Image: http://www.jamesdavidporter.com/photo%202.JPG]
Thanks!
Do you know this part? - by JimTheUmp - 02-13-2015, 03:16 AM
RE: Do you know this part? - by Ron Ramirez - 02-13-2015, 07:52 AM
RE: Do you know this part? - by klondike98 - 02-13-2015, 08:30 AM
RE: Do you know this part? - by morzh - 02-13-2015, 09:36 AM
RE: Do you know this part? - by Art Hoch - 03-11-2015, 04:30 PM
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
