38-116 Input Transformer Info
Additionally:
The original audio output transformer is rated at 8000 ohms primary impedance.
The Edcor GXPP15-4-8K is a near perfect replacement - 8000 ohms to 4 ohms. Icon_thumbup
https://www.edcorusa.com/gxpp15-4-8k
Great price, too, compared to a Hammond equivalent. The only problem I see is mounting it to your speaker, since the Edcor does not mount in the same way as the original transformer. But I'm sure you can figure something out.
38-116 output transformer - by bm071 - 02-13-2015, 02:03 PM
RE: 38-116 Input Transformer Info - by klondike98 - 02-27-2015, 02:04 PM
RE: 38-116 Input Transformer Info - by Diverted - 03-15-2015, 09:43 AM
RE: 38-116 Input Transformer Info - by Mondial - 03-15-2015, 11:24 PM
RE: 38-116 Input Transformer Info - by morzh - 03-16-2015, 10:00 AM
RE: 38-116 Input Transformer Info - by Diverted - 03-16-2015, 12:14 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 02:29 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 05:00 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 05:04 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 05:44 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 09:50 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:09 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:13 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:15 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:16 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:17 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:26 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:34 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:37 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:39 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:52 PM
RE: 38-116 output transformer - by morzh - 02-14-2015, 12:30 AM
RE: 38-116 output transformer - by SteveJB - 02-24-2015, 03:16 PM
38-116 Input Transformer Info - by bm071 - 02-27-2015, 01:52 PM
