38-116 Input Transformer Info
No, no, that is the audio interstage transformer. The audio output transformer mounts on the speaker.
The interstage transformer is a totally different monster. And if it requires replacement, you will have to have one custom made or else find one from a junk 38-116 chassis. This transformer has two separate secondaries, not a center tap. The split secondaries are necessary because of the radio's design; a center-tapped secondary won't work without some modifications to the set's original design. And it is a step-down transformer.
38-116 output transformer - by bm071 - 02-13-2015, 02:03 PM
RE: 38-116 Input Transformer Info - by klondike98 - 02-27-2015, 02:04 PM
RE: 38-116 Input Transformer Info - by Diverted - 03-15-2015, 09:43 AM
RE: 38-116 Input Transformer Info - by Mondial - 03-15-2015, 11:24 PM
RE: 38-116 Input Transformer Info - by morzh - 03-16-2015, 10:00 AM
RE: 38-116 Input Transformer Info - by Diverted - 03-16-2015, 12:14 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 02:29 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 05:00 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 05:04 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 05:44 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 09:50 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:09 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:13 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:15 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:16 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:17 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:26 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:34 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:37 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:39 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:52 PM
RE: 38-116 output transformer - by morzh - 02-14-2015, 12:30 AM
RE: 38-116 output transformer - by SteveJB - 02-24-2015, 03:16 PM
38-116 Input Transformer Info - by bm071 - 02-27-2015, 01:52 PM
There are currently 6079 online users. [Complete List]
» 1 Member(s) | 6078 Guest(s)
