Philco Model 112 Highboy
http://www.philcoradio.com/phorum/showth...p?tid=6087
One of the buys, $99, in 2013.
I say not above 130.
I bought a 111 a year and a half ago which shares the same chassis but is a highboy. $75.
Philco Model 112 Highboy - by RoyG - 02-14-2015, 10:28 PM
RE: Philco Model 112 Highboy - by morzh - 02-14-2015, 10:32 PM
RE: Philco Model 112 Highboy - by RoyG - 02-14-2015, 11:41 PM
RE: Philco Model 112 Highboy - by jerryhawthorne - 02-15-2015, 12:27 AM
RE: Philco Model 112 Highboy - by Arran - 02-15-2015, 05:38 AM
RE: Philco Model 112 Highboy - by codefox1 - 02-17-2015, 02:54 PM
RE: Philco Model 112 Highboy - by morzh - 02-17-2015, 03:03 PM
There are currently 7747 online users. [Complete List]
» 2 Member(s) | 7745 Guest(s)
