Philco Choke
HI Ron
I have a philco choke the number is 32-7491N do you have any info on this part? I need the milliampere rating. Icon_think
Thanks Joe
Philco Choke - by w4rtc - 02-16-2015, 04:01 PM
RE: Philco Choke - by Chuck Schwark - 02-16-2015, 04:04 PM
RE: Philco Choke - by w4rtc - 02-16-2015, 04:15 PM
RE: Philco Choke - by Chuck Schwark - 02-16-2015, 08:50 PM
RE: Philco Choke - by w4rtc - 02-16-2015, 11:06 PM
RE: Philco Choke - by Chuck Schwark - 02-17-2015, 09:51 AM
