Philco's most expensive radio
Oh, I see nothing wrong with bottom fishing, either. It's quite the thrill to take a dilapidated old hulk of a defunct set and make it look and sound like new again.
Philco's most expensive radio - by Chris Drumma - 12-20-2005, 08:50 AM
[No subject] - by Ron Ramirez - 12-20-2005, 09:39 AM
[No subject] - by 49Stude63 - 12-20-2005, 01:36 PM
[No subject] - by Ron Ramirez - 12-21-2005, 09:09 PM
[No subject] - by Bill Hutchinson - 12-21-2005, 10:18 PM
[No subject] - by Terry Judkins - 12-22-2005, 10:49 PM
[No subject] - by Ron Ramirez - 12-22-2005, 11:06 PM
[No subject] - by Ron Ramirez - 12-22-2005, 11:17 PM
[No subject] - by Guest - 03-12-2006, 08:26 PM
