Transformer 32-8055M
All loads disconnected, filaments too? There should be absolutely nothing loading it, not one pilot lamp or one tube remaining.
AND. The outputs checked for shorts. Unless you chose to clip off the wires.
If this is the case and it still runs hot, yes, you have a turn short, and the poor tranny has to be tossed or rewound.
Transformer 32-8055M - by zfrederick - 02-16-2015, 09:32 AM
RE: Transformer 32-8055M - by Ron Ramirez - 02-16-2015, 01:34 PM
RE: Transformer 32-8055M - by codefox1 - 02-17-2015, 10:55 AM
RE: Transformer 32-8055M - by morzh - 02-17-2015, 11:07 AM
RE: Transformer 32-8055M - by zfrederick - 02-18-2015, 03:44 PM
RE: Transformer 32-8055M - by morzh - 02-18-2015, 03:51 PM
RE: Transformer 32-8055M - by zfrederick - 02-18-2015, 04:29 PM
RE: Transformer 32-8055M - by morzh - 02-18-2015, 04:41 PM
RE: Transformer 32-8055M - by Eliot Ness - 02-18-2015, 06:08 PM
