Help on a GE Musiphonic
Sounds like it must have been a kitchen radio. The old PC boards get pretty bad around 35W4 and 50C5 due to all the heat. You should not need a chainsaw to get the IF cans off, as an air chisel should work just fine.
Help on a GE Musiphonic - by codefox1 - 12-18-2008, 02:57 AM
Re: Help on a GE Musiphonic - by rghines1 - 12-18-2008, 10:16 AM
Re: Help on a GE Musiphonic - by codefox1 - 12-18-2008, 07:15 PM
Re: Help on a GE Musiphonic - by codefox1 - 12-27-2008, 07:28 PM
Re: Help on a GE Musiphonic - by rghines1 - 12-29-2008, 09:21 PM
Re: Help on a GE Musiphonic - by codefox1 - 12-31-2008, 01:48 PM
Re: Help on a GE Musiphonic - by Jim Berg - 01-04-2009, 02:03 AM
Re: Help on a GE Musiphonic - by Texasrocker - 01-04-2009, 11:51 PM
Re: Help on a GE Musiphonic - by Arran - 01-05-2009, 11:33 PM
Eico 232 VTVM Schematic
