Farnsworth ACL-55 1949ish
You don't see a lot of Farnsworth sets so parts like the escutcheon (bezel) might be hard to find.
http://www.radiomuseum.org/r/philco_acl_...2_3c2.html
https://lacrosse.craigslist.org/atq/4852674775.html
At 7 tubes it isn't really a high-end set, but if you like it $30 sounds like a fair price as long as you think the cabinet issues can be easily fixed.
[url=https://lacrosse.craigslist.org/atq/4852674775.html][/url]
Farnsworth ACL-55 1949ish - by RodB - 02-19-2015, 05:21 PM
RE: Farnsworth ACL-55 1949ish - by Eliot Ness - 02-19-2015, 05:44 PM
RE: Farnsworth ACL-55 1949ish - by Joe Rossi - 02-19-2015, 06:15 PM
RE: Farnsworth ACL-55 1949ish - by Paul Philco322 - 02-19-2015, 07:59 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
