38 116 question
I think if you have actual corrosion the only good way to do the first cleaning is something abrasive, like a small round file, or sandpaper, or....
Then you follow with some protection, like your Deoxit etc.
38 116 question - by SteveJB - 02-20-2015, 05:23 PM
RE: 38 116 question - by morzh - 02-20-2015, 05:37 PM
RE: 38 116 question - by GarySP - 02-20-2015, 07:52 PM
RE: 38 116 question - by codefox1 - 02-22-2015, 12:00 PM
RE: 38 116 question - by Eliot Ness - 02-22-2015, 12:24 PM
RE: 38 116 question - by SteveJB - 02-22-2015, 02:49 PM
