Zenith H725-Problem Solved!
Hi Eric,  Ay-yi-yi, too many pin 6's, too many 12BA6's!  I'm presuming that you are referring to pin 6 on the 1st IF 12BA6 which connects to the 2nd IF can at the .002 cap, because pin 6 of the 2nd IF 12BA6 connects to the 3rd IF can.  No matter, re-check your ground connections between the 1st IF and the 3rd IF, and the both 12BA6 tube sockets and surrounding wires for continuity.  Keep us informed!  Joe
Joe
Zenith H725-Problem Solved! - by Eric Adams - 02-21-2015, 02:37 AM
RE: Zenith H725 - by Radioroslyn - 02-21-2015, 08:38 AM
RE: Zenith H725 - by Joe Rossi - 02-21-2015, 08:40 AM
RE: Zenith H725 - by Eliot Ness - 02-21-2015, 08:43 AM
RE: Zenith H725 - by Eric Adams - 02-21-2015, 11:12 AM
RE: Zenith H725 - by Ron Ramirez - 02-21-2015, 11:31 AM
RE: Zenith H725 - by Eric Adams - 02-21-2015, 11:47 AM
RE: Zenith H725 - by Eric Adams - 02-21-2015, 01:06 PM
RE: Zenith H725-Problem Solved! - by Ron Ramirez - 02-21-2015, 01:08 PM
RE: Zenith H725-Problem Solved! - by Eric Adams - 02-21-2015, 03:25 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 10137 online users. [Complete List]
» 2 Member(s) | 10135 Guest(s)
