philco 41-245
hey guys
bought a radio for parts  not too bad shape
decided to restore it some one installed head phone jacks ? least I think they are
found the speaker wire cut  from fiber board to speaker cone.  copper ribbon wire string in it ?
how do I solder a piece of wire to it
I replaced lytics and tubes ,jumped speaker It plays but low and static
sam
philco 41-245 - by sam - 02-22-2015, 01:43 AM
RE: philco 41-245 - by morzh - 02-22-2015, 11:22 AM
RE: philco 41-245 - by simplex1040 - 02-27-2015, 01:38 PM
