46-421 capacitor
Hello all, currently working on a 46-421. One of the caps ( .2-400 ) has wire wrapped around it to make a coil.
No problem in replacing the cap, but the new cap will much smaller in diameter so the coil of wire will not be tight against the cap.
Does this matter or should I re-wrap the the wire around the new cap. ( wouldn't that change the value of the coil).
Thanks
RF
46-421 capacitor - by RF7590 - 02-22-2015, 08:45 PM
RE: 46-421 capacitor - by klondike98 - 02-22-2015, 10:31 PM
RE: 46-421 capacitor - by sam - 02-23-2015, 12:50 PM
RE: 46-421 capacitor - by K7Sparky - 02-24-2015, 01:55 PM
RE: 46-421 capacitor - by klondike98 - 02-24-2015, 11:35 PM
RE: 46-421 capacitor - by sam - 02-25-2015, 05:02 AM
RE: 46-421 capacitor - by Ron Ramirez - 02-25-2015, 08:21 AM
RE: 46-421 capacitor - by K7Sparky - 02-25-2015, 03:21 PM
RE: 46-421 capacitor - by codefox1 - 02-26-2015, 09:58 AM
RE: 46-421 capacitor - by morzh - 02-26-2015, 11:51 AM
RE: 46-421 capacitor - by Chuck Schwark - 02-26-2015, 01:51 PM
RE: 46-421 capacitor - by K7Sparky - 02-27-2015, 02:03 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
