Philco 37-610B Veneer - Opinions please.
Oh, now I get it. Very interesting!
I've got some really nice quality curly maple veneer. I think I'm going to change the entire look of this cabinet.
RE: Philco 37-610B Veneer - Opinions please. - by JimTheUmp - 02-23-2015, 12:26 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3275 online users. [Complete List]
» 1 Member(s) | 3274 Guest(s)
