Philco 38-116 Audio Input?
One thing I always do before starting on a radio with a power transformer is checking the power tansformer. If it is shot, depending on the radio you might reconsider the whole resto effort.
Philco 38-116 Audio Input? - by louxwe - 02-23-2015, 01:42 AM
RE: Philco 38-116 Audio Input? - by morzh - 02-23-2015, 09:40 AM
RE: Philco 38-116 Audio Input? - by louxwe - 02-23-2015, 12:59 PM
RE: Philco 38-116 Audio Input? - by sam - 02-23-2015, 01:00 PM
RE: Philco 38-116 Audio Input? - by morzh - 02-23-2015, 02:29 PM
RE: Philco 38-116 Audio Input? - by morzh - 02-23-2015, 06:12 PM
RE: Philco 38-116 Audio Input? - by louxwe - 02-24-2015, 12:53 AM
RE: Philco 38-116 Audio Input? - by sam - 02-24-2015, 01:03 AM
RE: Philco 38-116 Audio Input? - by K7Sparky - 02-25-2015, 07:18 PM
