38-116 Input Transformer Info
See if this is what you need. I tried a PM, but I cant tell if it is going trouugh so I am reposting here.
This is what I measured (all from chassis ground):
from the plate of the 6J5 driver it is 256 vdc
From the positive side of e-cap 70B it is 256 vdc.
Then I had my chassis upside down in a cradle with the transformer on the bottom. Looking at the 6 pins, there are three vertically on the left side and 3 vertically on the right side.
I get the following starting top left, then middle, then bottom left:
-21 vdc
-21 vdc
-21 vdc
On the right side, I get top, middle and bottom:
-21 vdc
256 vdc
256 vdc
My set read about 20-30 volts low on all the tubes, but it plays well.  I don't know old the same holds true here.
Here is a picture from the bottom as I described it above (the trans is between the bakelite bock and the 6J5 Driver tube socket:
http://i1033.photobucket.com/albums/a414...uhj9nw.jpg
38-116 output transformer - by bm071 - 02-13-2015, 02:03 PM
RE: 38-116 Input Transformer Info - by klondike98 - 02-27-2015, 02:04 PM
RE: 38-116 Input Transformer Info - by Diverted - 03-15-2015, 09:43 AM
RE: 38-116 Input Transformer Info - by Mondial - 03-15-2015, 11:24 PM
RE: 38-116 Input Transformer Info - by morzh - 03-16-2015, 10:00 AM
RE: 38-116 Input Transformer Info - by Diverted - 03-16-2015, 12:14 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 02:29 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 05:00 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 05:04 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 05:44 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 09:50 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:09 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:13 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:15 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:16 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:17 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:26 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:34 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:37 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:39 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:52 PM
RE: 38-116 output transformer - by morzh - 02-14-2015, 12:30 AM
RE: 38-116 output transformer - by SteveJB - 02-24-2015, 03:16 PM
38-116 Input Transformer Info - by bm071 - 02-27-2015, 01:52 PM
