Philco Fibre Wrench - Homebrew
ummm.. is that also known as:, ... "busting a nut"? ... if so, I never needed a special wrench for that at all! Now exact "alignment" is a different matter altogether! My Wife says my alignment-tools are still workin just fine!! Ive aligned her radio several times!! Selectivity & sensitivity were GREAT!! Everything was fine till I mentioned the vintage IF cans were smaller than usual! Pls excuse my sense of humor!, your alignment inventions are GREATindeed Icon_wink !!
Philco Fibre Wrench - Homebrew - by etech - 12-10-2008, 03:17 PM
Re: Philco Fibre Wrench - Homebrew - by BDM - 12-10-2008, 04:49 PM
Re: Philco Fibre Wrench - Homebrew - by etech - 12-11-2008, 10:18 AM
Re: Philco Fibre Wrench - Homebrew - by Arran - 12-31-2008, 02:14 AM
Re: Philco Fibre Wrench - Homebrew - by Jim Berg - 01-04-2009, 01:22 AM
Re: Philco Fibre Wrench - Homebrew - by etech - 01-04-2009, 09:47 AM
Re: Philco Fibre Wrench - Homebrew - by Texasrocker - 01-05-2009, 02:41 AM
Re: Philco Fibre Wrench - Homebrew - by radiorich - 02-05-2009, 05:14 PM
There are currently 4394 online users. [Complete List]
» 1 Member(s) | 4393 Guest(s)
