philco 620,,,#32-1647 if transformer
No Mike, life is just fine!  Hope your keeping warm.
Jerry
RE: philco 620,,,#32-1647 if transformer - by jerryhawthorne - 02-25-2015, 01:08 AM
There are currently 6206 online users. [Complete List]
» 1 Member(s) | 6205 Guest(s)
