philco 620,,,#32-1647 if transformer
Made mistake on ohms,,should read 12 ohms---on all of above,,,sorry
RE: philco 620,,,#32-1647 if transformer - by Kenneth F. Besso Jr. - 02-25-2015, 02:01 AM
