Finihes the Rogers 7M932
Great job!!! Really like the look of the dial scale and tuner.
Finihes the Rogers 7M932 - by Dan Walker - 02-20-2015, 12:44 AM
RE: Finihes the Rogers 7M932 - by sam - 02-20-2015, 04:31 AM
RE: Finihes the Rogers 7M932 - by Arran - 02-20-2015, 05:49 AM
RE: Finihes the Rogers 7M932 - by klondike98 - 02-20-2015, 09:01 AM
RE: Finihes the Rogers 7M932 - by Dan Walker - 02-20-2015, 10:40 AM
RE: Finihes the Rogers 7M932 - by Arran - 02-25-2015, 03:31 AM
RE: Finihes the Rogers 7M932 - by VntgRads - 02-20-2015, 01:04 PM
RE: Finihes the Rogers 7M932 - by PhilcoJohn - 02-25-2015, 10:34 AM
RE: Finihes the Rogers 7M932 - by KCMike - 02-25-2015, 07:20 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
