Philco Part
Hi all
I started to align my philco 37-675 in the alignment instructions to tune the RF and ANT. it refers to a part 45-2325 clipped
to the trimmer in the band 5 and band 4 to tune the these caps. Does anyone know anything about the 45-2325 item?  Icon_think
Thanks
Joe
Philco Part - by w4rtc - 02-25-2015, 08:55 PM
RE: Philco Part - by Ron Ramirez - 02-27-2015, 07:38 AM
RE: Philco Part - by w4rtc - 02-27-2015, 09:36 AM
There are currently 6427 online users. [Complete List]
» 1 Member(s) | 6426 Guest(s)
