wireless Phono
HOOOLLLLYYYY COOOWWWWW!!! That thing went for 81 buckazoids! Icon_eek A bit ridiculous, if you ask me, for one of these units.
No, I take that back. Not just a bit ridiculous - more like WAY over the top. Don't think I've ever seen an RP-x bring that much money, save for the more rare RP-3 that looks like a big Mystery Control on steroids, only without the dial.
Chris, hang in there, there will be another one, and more reasonably priced. (I'm assuming you aren't "monique-renea," right? ...Right? Icon_wink )
wireless Phono - by Chris Drumma - 12-18-2005, 11:29 AM
[No subject] - by Ron Ramirez - 12-18-2005, 11:45 AM
[No subject] - by Chuck Schwark - 12-18-2005, 11:48 AM
[No subject] - by Ron Ramirez - 12-18-2005, 11:59 AM
[No subject] - by Chris Drumma - 12-18-2005, 01:14 PM
[No subject] - by Ron Ramirez - 12-22-2005, 11:13 AM
[No subject] - by Chris Drumma - 12-22-2005, 01:35 PM
[No subject] - by Ron Ramirez - 12-22-2005, 05:35 PM
Philco 91 Tuning Condenser
