Vibrator Condenser
(02-26-2015, 05:16 PM)David Wrote:  Pat .01mf equals 10000pf  2000 volts you will be looking at a ceramic disc type first place to check would be mousser. David
Know that,  but my question is about a "vibrator condenser."
Vibrator Condenser - by Patrick - 02-26-2015, 05:04 PM
RE: Vibrator Condenser - by David - 02-26-2015, 05:16 PM
RE: Vibrator Condenser - by Patrick - 02-26-2015, 06:07 PM
RE: Vibrator Condenser - by morzh - 02-26-2015, 05:37 PM
RE: Vibrator Condenser - by Patrick - 02-26-2015, 06:13 PM
RE: Vibrator Condenser - by morzh - 02-26-2015, 07:12 PM
RE: Vibrator Condenser - by Patrick - 02-26-2015, 08:19 PM
RE: Vibrator Condenser - by Ron Ramirez - 02-26-2015, 09:00 PM
RE: Vibrator Condenser - by Patrick - 02-26-2015, 09:16 PM
RE: Vibrator Condenser - by K7Sparky - 02-26-2015, 09:34 PM
RE: Vibrator Condenser - by K7Sparky - 02-26-2015, 09:40 PM
RE: Vibrator Condenser - by Patrick - 02-27-2015, 09:55 AM
