Philco 37-630 questions
Can anyone please tell me item what #68 on the philco 37-630 schematic is / does? It reads that it is a "wave switch antenna" but it looks like a large resister. Mine is a tar covered white dog bone with a red strip? Is there a way to test this?
Any help would be appreciated.
Thank you.
Joe
Philco 37-630 questions - by Ovila Joseph - 02-11-2015, 02:19 PM
RE: Philco 37-630 questions - by klondike98 - 02-27-2015, 10:42 AM
RE: Philco 37-630 questions - by Ovila Joseph - 02-27-2015, 07:33 PM
RE: Philco 37-630 questions - by klondike98 - 02-27-2015, 08:19 PM
RE: Philco 37-630 questions - by Ovila Joseph - 02-28-2015, 10:25 PM
RE: Philco 37-630 questions - by klondike98 - 03-01-2015, 05:16 PM
RE: Philco 37-630 questions - by Ron Ramirez - 03-02-2015, 08:41 AM
RE: Philco 37-630 questions - by mikethedruid - 08-15-2015, 07:48 PM
Philco 37-630 item number 68 wave switch antenna - by Ovila Joseph - 02-26-2015, 09:15 PM
There are currently 5391 online users. [Complete List]
» 1 Member(s) | 5390 Guest(s)
