Vibrator Condenser
(02-26-2015, 09:40 PM)K7Sparky Wrote:  OK
What's under the hood?
Seems the model is in question.  Is it a DC radio that has a vibrator supply?
Check Ron's answer. Thanks for the info.
Vibrator Condenser - by Patrick - 02-26-2015, 05:04 PM
RE: Vibrator Condenser - by David - 02-26-2015, 05:16 PM
RE: Vibrator Condenser - by Patrick - 02-26-2015, 06:07 PM
RE: Vibrator Condenser - by morzh - 02-26-2015, 05:37 PM
RE: Vibrator Condenser - by Patrick - 02-26-2015, 06:13 PM
RE: Vibrator Condenser - by morzh - 02-26-2015, 07:12 PM
RE: Vibrator Condenser - by Patrick - 02-26-2015, 08:19 PM
RE: Vibrator Condenser - by Ron Ramirez - 02-26-2015, 09:00 PM
RE: Vibrator Condenser - by Patrick - 02-26-2015, 09:16 PM
RE: Vibrator Condenser - by K7Sparky - 02-26-2015, 09:34 PM
RE: Vibrator Condenser - by K7Sparky - 02-26-2015, 09:40 PM
RE: Vibrator Condenser - by Patrick - 02-27-2015, 09:55 AM
