Philco 37-630 questions
Looking at the under chassis diagram and the schematic a bit more, it looks to me like the under chassis diagram dogbone resistor labelled 68 should really be labelled 64, i.e. the 2 watt 9K resistor attached.  Shouldn't be tar covered though.  A white body, black ended with a red dot or center stripe would be a 9K resistor.
Philco 37-630 questions - by Ovila Joseph - 02-11-2015, 02:19 PM
RE: Philco 37-630 questions - by klondike98 - 02-27-2015, 10:42 AM
RE: Philco 37-630 questions - by Ovila Joseph - 02-27-2015, 07:33 PM
RE: Philco 37-630 questions - by klondike98 - 02-27-2015, 08:19 PM
RE: Philco 37-630 questions - by Ovila Joseph - 02-28-2015, 10:25 PM
RE: Philco 37-630 questions - by klondike98 - 03-01-2015, 05:16 PM
RE: Philco 37-630 questions - by Ron Ramirez - 03-02-2015, 08:41 AM
RE: Philco 37-630 questions - by mikethedruid - 08-15-2015, 07:48 PM
There are currently 5797 online users. [Complete List]
» 1 Member(s) | 5796 Guest(s)
