38-116 Input Transformer Info
Just wanted to say thanks to Chuck at the Philco Repair Bench. With his help and a little after market vintage tech info  Heyboer will be able to re-produce this step down input transformer. It should turn out to be a real close or same  match of the original.   If anyone is in need I will have a part number/specs etc. ...soon.
Thank you everyone!!!!
Bob
38-116 output transformer - by bm071 - 02-13-2015, 02:03 PM
RE: 38-116 Input Transformer Info - by klondike98 - 02-27-2015, 02:04 PM
RE: 38-116 Input Transformer Info - by Diverted - 03-15-2015, 09:43 AM
RE: 38-116 Input Transformer Info - by Mondial - 03-15-2015, 11:24 PM
RE: 38-116 Input Transformer Info - by morzh - 03-16-2015, 10:00 AM
RE: 38-116 Input Transformer Info - by Diverted - 03-16-2015, 12:14 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 02:29 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 05:00 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 05:04 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 05:44 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 09:50 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:09 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:13 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:15 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:16 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:17 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:26 PM
RE: 38-116 output transformer - by morzh - 02-13-2015, 11:34 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:37 PM
RE: 38-116 output transformer - by Ron Ramirez - 02-13-2015, 11:39 PM
RE: 38-116 output transformer - by bm071 - 02-13-2015, 11:52 PM
RE: 38-116 output transformer - by morzh - 02-14-2015, 12:30 AM
RE: 38-116 output transformer - by SteveJB - 02-24-2015, 03:16 PM
38-116 Input Transformer Info - by bm071 - 02-27-2015, 01:52 PM
There are currently 6161 online users. [Complete List]
» 1 Member(s) | 6160 Guest(s)
