Model 111
Have a 111, restored last fall, yes, nice set and is the only superhet out off all those other radios in this and similar cabinets of the time (with falling leaves cloth and grill arches).
Model 111 - by simplex1040 - 02-27-2015, 01:18 PM
RE: Model 111 - by klondike98 - 02-27-2015, 01:31 PM
RE: Model 111 - by morzh - 02-27-2015, 03:04 PM
RE: Model 111 - by jerryhawthorne - 02-28-2015, 01:19 AM
RE: Model 111 - by simplex1040 - 02-28-2015, 11:05 AM
There are currently 7364 online users. [Complete List]
» 3 Member(s) | 7361 Guest(s)
