511 Issue
Hey Phorum,
I've completed restoring the 511 and the set is working although at a very low volume (set is grounded/using a 20-ft antenna/tried 2 good 80s/have not yet attempted neutralization).
I cannot identify the connections on the transformer, but it says that terminals 1-3 should be 375 V-AC.  Only 2 of my terminals have high voltage, but only 190 V-AC.
Interestingly enough, I bought a complete junker 511 for parts and it also shows 190 V on the transformer at the same 2 positions....is this coincidence or did both transformers go bad the same way?  Is it definitely bad?  I've never rebuilt a transformer before....should I try this or look for another?  Any help is appreciated.
Mark
511 Issue - by bdi1976 - 02-28-2015, 09:26 AM
RE: 511 Issue - by morzh - 02-28-2015, 02:11 PM
RE: 511 Issue - by bdi1976 - 03-02-2015, 12:27 AM
RE: 511 Issue - by morzh - 03-02-2015, 09:38 AM
RE: 511 Issue - by Radioroslyn - 03-02-2015, 06:27 PM
RE: 511 Issue - by bdi1976 - 03-02-2015, 09:21 PM
RE: 511 Issue - by bdi1976 - 03-14-2015, 12:41 PM
RE: 511 Issue - by morzh - 03-14-2015, 12:53 PM
RE: 511 Issue - by Radioroslyn - 03-14-2015, 05:02 PM
RE: 511 Issue - by bdi1976 - 03-14-2015, 05:22 PM
