Philco model 19B I.F.
I have just restored a Philco chassis 319 ( Made in Canada version of 19/89 ) and am about to do an alignment on it.
I am confused since the I.F. frequency is indicated as 260KHz or 460KHz depending on what document you are using…
Can anyone provide a definitive answer on the I.F. frequency of the 319 chassis which was used in the model 19 series in Canada? I am going to guess 460KHz for now…it would be obvious I assume once I start the procedure…
Philco model 19B I.F. - by VE6ZRT - 02-28-2015, 04:36 PM
RE: Philco model 19B I.F. - by Ron Ramirez - 02-28-2015, 07:31 PM
RE: Philco model 19B I.F. - by VE6ZRT - 03-02-2015, 09:22 AM
RE: Philco model 19B I.F. - by klondike98 - 03-02-2015, 10:10 AM
RE: Philco model 19B I.F. - by VE6ZRT - 03-02-2015, 04:10 PM
