removed cap, lost radio on my 41-608
And if you want them to look right, buy the tube axial types and stuff them inide the old ones, you can reserve the old wires and use them.
RE: removed cap, lost radio on my 41-608 - by morzh - 03-02-2015, 09:58 AM
