Philco Model 81-need help please
(03-02-2015, 10:59 AM)morzh Wrote:  Yes, it is twisted, look at the links Klondike gave you.
Thanks morzh.  I have read the links.  My comment should have been that the loose end of the wire does not physically connect to a lug somewhere.  I will add some wire and do the wrapping and see if that helps.  I have already replaced the 4 meg resistor with a   2 meg as mentioned in the Service Hints.
Jay
Philco Model 81-need help please - by Jay Thomas - 03-02-2015, 12:25 AM
RE: Philco Model 81-need help please - by morzh - 03-02-2015, 09:32 AM
RE: Philco Model 81-need help please - by morzh - 03-02-2015, 10:59 AM
RE: Philco Model 81-need help please - by Jay Thomas - 03-02-2015, 11:18 AM
RE: Philco Model 81-need help please - by morzh - 03-03-2015, 05:51 PM
There are currently 5730 online users. [Complete List]
» 1 Member(s) | 5729 Guest(s)
