Philco Model 65 with Speaker Model F-10
The speaker on e-bay has the plug that I need. Thanks. I'm still looking for 4 conductor brown cloth covered speaker wire. I found some "bugi-cord" that is almost brown and slipped the rubber out of it. It is not cotton but may work as a last resort as a cover for for the new wires? If I can find a bungi-cord that is closer in color to the brown speaker cord that may be the best I can do?
Thanks again,
Philco Model 65 with Speaker Model F-10 - by Guest - 12-20-2005, 12:52 PM
[No subject] - by Ron Ramirez - 12-21-2005, 06:16 PM
[No subject] - by Ron Ramirez - 12-21-2005, 06:20 PM
Speaker on E-bay - by Guest - 12-22-2005, 01:48 PM
[No subject] - by Ron Ramirez - 12-30-2005, 12:50 AM
Philco Speaker - Model F-10 - by Guest - 01-02-2006, 05:06 PM
Eico 232 VTVM Schematic
There are currently 6474 online users. [Complete List]
» 1 Member(s) | 6473 Guest(s)
