Question about a Philco 39-6C
Hi Tom, welcome to the Phorum!!!
Checkout the moldel number info and the letter info
If that doesn't help, post a picture.
Question about a Philco 39-6C - by Tom72 - 03-03-2015, 12:04 PM
RE: Question about a Philco 39-6C - by klondike98 - 03-03-2015, 12:43 PM
RE: Question about a Philco 39-6C - by Tom72 - 03-03-2015, 02:54 PM
There are currently 6567 online users. [Complete List]
» 2 Member(s) | 6565 Guest(s)
