The Fisher 440-T FM Receiver
More scope pictures at the left channel "main" speaker output.
Volume 1/4 of the way up:
[Image: http://www.philcoradio.com/images/phorum...0-T_07.jpg]
Volume 1/2 way up:
[Image: http://www.philcoradio.com/images/phorum...0-T_08.jpg]
Volume 2/3 up (as far as I wanted to turn it as it was quite loud at this point):
[Image: http://www.philcoradio.com/images/phorum...0-T_09.jpg]
DC voltage at point DD was 48.9 volts with volume all the way down; it dropped to 44.6 volts with the volume 2/3 of the way up.
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2015, 09:56 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
