The Fisher 440-T FM Receiver
Threads: 562
Yes this is what I was talking about, if the seond and third pics have the same scale, you simply overamplify and you might be OK and need to work at lower input signal.
Will have to compare both channels to see if this might be the case.
Mañana.
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2015, 11:12 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
