What should I do here?
Ok so you all know I got that 45 butterfly and rebuilt it. Mike did my chassis and she looks good and plays great.
I recently came into another 45 cabinet only. It is complete and just needs a new finish. The one I restored had nothing salvageable but the top molding from the top, Front was dead except for the veneer but I had a good bottom good grill cloth, and ok sides.
The only issue as I found out now from looking at the new cabinet is that someone cut the bottom front molding of my rebuilt one flat and it should have a 45 degree angle to the floor.
My dilemma is this, do I take my chassis and put it on the new cabinet or leave it in  the one I already re-did?
The original one is a half new cabinet so I think something all original would be better and I could sell or trade the rebuilt cabinet.
What do you guys think?
Keep the old rebuilt?
Go with the all original?
Kirk
What should I do here? - by OldRestorer - 03-04-2015, 12:06 PM
RE: What should I do here? - by Eliot Ness - 03-04-2015, 12:20 PM
RE: What should I do here? - by OldRestorer - 03-04-2015, 12:42 PM
RE: What should I do here? - by sam - 03-04-2015, 12:59 PM
RE: What should I do here? - by OldRestorer - 03-04-2015, 01:06 PM
RE: What should I do here? - by VntgRads - 03-04-2015, 07:51 PM
RE: What should I do here? - by Warren - 03-04-2015, 08:35 PM
RE: What should I do here? - by morzh - 03-04-2015, 09:38 PM
RE: What should I do here? - by Ron Ramirez - 03-04-2015, 11:28 PM
There are currently 8477 online users. [Complete List]
» 1 Member(s) | 8476 Guest(s)
