The Fisher 440-T FM Receiver
#80
OK, so at 1/2 volume you have normal signal driven into the transformer.
At the same time from your previous pics at 1/2 volume your output starts distorting. And both channels are doing the same.
This tells me you might be OK and what you are seeing could be normal, or at least agree with the design.
Definitely look across the power, see if all is recapped, like C19/C20, C23/C24 and such (you probably recapped C29/C30). Also the power supply caps.
Now, does the input signal come from inside the amp or do you supply it from outside? Is it a test tone or something?
The sch says "11.8V across 4 Ohm load", which makes it 34W output.
What I wanted to know was what is your scope's V/div so we know what is the peak (or RMS if you use a meter) amplitude where it starts distorting. It is possible you are exceeding the max power and this would be OK, as the distortion should not occur only before exceeding it.
The gain is about 26 so if you supply 1V of input this would exceed it. You should be roughly under 500mV RMS (700 peak or 1.4V p-p) on your input signal.
The Fisher 440-T FM Receiver - by Ron Ramirez - 03-01-2014, 10:51 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-01-2014, 10:54 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-01-2014, 11:00 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-01-2014, 11:08 PM
RE: The Fisher 440-T FM Receiver - by skyscraper - 03-01-2014, 11:13 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-01-2014, 11:18 PM
RE: The Fisher 440-T FM Receiver - by skyscraper - 03-01-2014, 11:26 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-02-2014, 09:37 AM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-02-2014, 08:08 PM
RE: The Fisher 440-T FM Receiver - by BrendaAnnD - 03-02-2014, 10:22 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-02-2014, 10:26 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-02-2014, 10:34 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2014, 10:10 AM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2014, 11:08 AM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-03-2014, 11:20 AM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2014, 12:54 PM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-03-2014, 01:17 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2014, 01:28 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2014, 01:51 PM
RE: The Fisher 440-T FM Receiver - by BrendaAnnD - 03-03-2014, 02:46 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2014, 04:25 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2014, 04:48 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2014, 04:51 PM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-03-2014, 05:16 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2014, 06:50 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2014, 06:51 PM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-03-2014, 07:21 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2014, 09:53 PM
RE: The Fisher 440-T FM Receiver - by BrendaAnnD - 03-03-2014, 10:56 PM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-03-2014, 11:39 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-04-2014, 10:53 AM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-04-2014, 11:14 AM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-04-2014, 07:58 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-10-2014, 08:45 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-13-2014, 05:53 AM
RE: The Fisher 440-T FM Receiver - by BrendaAnnD - 03-13-2014, 10:09 AM
RE: The Fisher 440-T FM Receiver - by morzh - 03-13-2014, 10:21 AM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-13-2014, 04:40 PM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-13-2014, 06:05 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-13-2014, 07:01 PM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-13-2014, 08:05 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-13-2014, 08:08 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-13-2014, 08:10 PM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-13-2014, 08:36 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-13-2014, 08:37 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-13-2014, 08:43 PM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-13-2014, 08:50 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-13-2014, 08:55 PM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-13-2014, 09:07 PM
RE: The Fisher 440-T FM Receiver - by BrendaAnnD - 03-13-2014, 10:12 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-15-2014, 10:07 AM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-15-2014, 11:22 AM
RE: The Fisher 440-T FM Receiver - by Mondial - 03-15-2014, 11:34 AM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-15-2014, 12:16 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-15-2014, 06:35 PM
RE: The Fisher 440-T FM Receiver - by BrendaAnnD - 03-15-2014, 09:01 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-15-2014, 10:39 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-16-2014, 03:41 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 10-04-2014, 10:34 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 02-20-2015, 11:33 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 02-26-2015, 10:12 AM
RE: The Fisher 440-T FM Receiver - by morzh - 02-26-2015, 12:09 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 02-26-2015, 09:05 PM
RE: The Fisher 440-T FM Receiver - by morzh - 02-26-2015, 11:17 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2015, 12:46 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2015, 01:07 PM
RE: The Fisher 440-T FM Receiver - by PhilcoMike - 03-03-2015, 03:37 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2015, 03:42 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2015, 04:19 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2015, 04:43 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2015, 09:56 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2015, 10:39 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2015, 10:46 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2015, 10:52 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2015, 10:57 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-03-2015, 11:04 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-03-2015, 11:12 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-04-2015, 11:03 AM
RE: The Fisher 440-T FM Receiver - by PhilcoMike - 03-04-2015, 12:50 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-04-2015, 02:21 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-04-2015, 02:36 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-04-2015, 02:44 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-04-2015, 06:41 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-04-2015, 06:44 PM
RE: The Fisher 440-T FM Receiver - by PhilcoMike - 03-06-2015, 02:17 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-06-2015, 02:50 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-11-2015, 02:49 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-11-2015, 03:44 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-11-2015, 03:58 PM
RE: The Fisher 440-T FM Receiver - by morzh - 03-11-2015, 06:46 PM
RE: The Fisher 440-T FM Receiver - by codefox1 - 03-14-2015, 10:26 AM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-14-2015, 10:15 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-17-2015, 08:34 PM
RE: The Fisher 440-T FM Receiver - by PhilcoMike - 03-18-2015, 01:17 PM
RE: The Fisher 440-T FM Receiver - by Ron Ramirez - 03-18-2015, 01:53 PM
I forgot to make mention of it the other day, but last week I corrected another error on my schematic (applies to both R...jrblasde — 09:27 PM
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
There are currently 1588 online users. [Complete List]
» 1 Member(s) | 1587 Guest(s)
