ID this Radio?
Don't worry, there are plenty of chassis that will fit (65, 87, 76, 95). I probably have more than one kicking around here in restorable condition. They are heavy buggers, though.
ID this Radio? - by jayoungs - 01-07-2009, 11:06 AM
Re: ID this Radio? - by Chuck Schwark - 01-07-2009, 11:12 AM
Re: ID this Radio? - by jayoungs - 01-07-2009, 11:57 AM
Re: ID this Radio? - by Chuck Schwark - 01-07-2009, 12:55 PM
Re: ID this Radio? - by jayoungs - 01-07-2009, 02:45 PM
Re: ID this Radio? - by Ron Ramirez - 01-07-2009, 06:46 PM
Re: ID this Radio? - by Michael Dennis - 01-07-2009, 11:18 PM
Re: ID this Radio? - by jayoungs - 01-09-2009, 11:09 AM
Re: ID this Radio? - by jayoungs - 01-11-2009, 07:49 PM
Re: ID this Radio? - by scooby214 - 01-11-2009, 09:25 PM
There are currently 8438 online users. [Complete List]
» 1 Member(s) | 8437 Guest(s)
