Another Rogers
I once had a 6 tube Rogers Majestic console and its cabinet was stunning with a metal tag in back from the furniture company that had made the cabinet. They also have names for each cabinet usually stamped in back in white paint like Zenith did too.
Another Rogers - by Dan Walker - 03-01-2015, 10:53 PM
RE: Another Rogers - by morzh - 03-01-2015, 10:56 PM
RE: Another Rogers - by klondike98 - 03-01-2015, 11:27 PM
RE: Another Rogers - by PhilcoMike - 03-02-2015, 05:10 PM
RE: Another Rogers - by Joe Rossi - 03-02-2015, 08:53 PM
RE: Another Rogers - by y2kbruce - 03-05-2015, 07:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6818 online users. [Complete List]
» 1 Member(s) | 6817 Guest(s)
