  • 1 Vote(s) - 5 Average
So where should I start.... Philco 38-116
About replacing the capacitors. You do replace ALL the paper caps and electrolytic caps but you don't have to normally replace the mica capacitors unless you find a bad one. So both statements are true. You don't replace every single capacitor just the paper and electrolytic ones.
To start off you can use an ohm meter to measure between the different  wires on the transformer to see if the resistance is correct. The schematic should show you what  the ohms should be between which wires from the transformer.
RE: So where should I start.... Philco 38-116 - by Warren - 03-05-2015, 11:51 PM
There are currently 5012 online users. [Complete List]
» 1 Member(s) | 5011 Guest(s)
