Resistor values question
No, they are NOT to the chassis.
Again, look at the power switch (probably coupled with your volume?).
One wire goes to the power cord, another should go to the filaments' string AND to the negative of these caps.
This is NOT a hot chassis radio, and the chassis is coupled into that negative via a capacitor C16. BTW one pin of that C16 is on the chassis and another is on that negative plus power switch plus filaments.
Resistor values question - by OldRestorer - 03-05-2015, 01:29 PM
RE: Resistor values question - by morzh - 03-05-2015, 01:41 PM
RE: Resistor values question - by OldRestorer - 03-05-2015, 02:02 PM
RE: Resistor values question - by Kestas - 03-05-2015, 02:22 PM
RE: Resistor values question - by OldRestorer - 03-05-2015, 03:05 PM
RE: Resistor values question - by sam - 03-05-2015, 03:22 PM
RE: Resistor values question - by morzh - 03-05-2015, 04:25 PM
RE: Resistor values question - by OldRestorer - 03-05-2015, 05:02 PM
RE: Resistor values question - by sam - 03-05-2015, 05:13 PM
RE: Resistor values question - by morzh - 03-05-2015, 05:16 PM
RE: Resistor values question - by OldRestorer - 03-06-2015, 10:39 AM
RE: Resistor values question - by morzh - 03-06-2015, 10:44 AM
RE: Resistor values question - by OldRestorer - 03-06-2015, 10:53 AM
RE: Resistor values question - by OldRestorer - 03-06-2015, 10:58 AM
RE: Resistor values question - by sam - 03-06-2015, 11:10 AM
RE: Resistor values question - by morzh - 03-06-2015, 11:12 AM
RE: Resistor values question - by OldRestorer - 03-06-2015, 01:24 PM
RE: Resistor values question - by Radioroslyn - 03-06-2015, 02:34 PM
RE: Resistor values question - by Radioroslyn - 03-06-2015, 03:09 PM
RE: Resistor values question - by OldRestorer - 03-06-2015, 10:08 PM
RE: Resistor values question - by OldRestorer - 03-09-2015, 12:01 PM
RE: Resistor values question - by morzh - 03-09-2015, 12:47 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 10:03 AM
RE: Resistor values question - by Kestas - 03-19-2015, 11:41 AM
RE: Resistor values question - by OldRestorer - 03-19-2015, 01:10 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 02:55 PM
RE: Resistor values question - by Radioroslyn - 03-19-2015, 04:08 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 05:40 PM
RE: Resistor values question - by Radioroslyn - 03-19-2015, 06:06 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 07:40 PM
RE: Resistor values question - by Radioroslyn - 03-19-2015, 07:45 PM
RE: Resistor values question - by OldRestorer - 03-19-2015, 08:02 PM
RE: Resistor values question - by Radioroslyn - 03-19-2015, 09:54 PM
RE: Resistor values question - by Mondial - 03-19-2015, 11:09 PM
RE: Resistor values question - by OldRestorer - 03-20-2015, 12:59 PM
RE: Resistor values question - by OldRestorer - 03-20-2015, 01:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
