RCA Radio Apparatus for Amateur and Experimental Use
This link popped up on the Delaware Valley Historical Radio Club mail reflector.
http://www.skywaves.ar88.net/Docs/default.html
An RCA 1921 publication "with Instructions for Continuous Wave Operation."  The link is to the full publication.
RCA Radio Apparatus for Amateur and Experimental Use - by klondike98 - 03-07-2015, 03:33 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3906 online users. [Complete List]
» 1 Member(s) | 3905 Guest(s)
