Restoring a Model 19 Code 126
I have used clear lacquer or clear nail polish to reseal coils, no problems yet with wither one.
I would not use wax (paraffin) as you would just be re-creating what caused the problem in the first place. It was thought at the time that wax would keep moisture out. What happened was, it not only allowed moisture in, but it also held it in.
Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 12:18 AM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-06-2015, 08:55 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 02:41 PM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-06-2015, 03:03 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 03:59 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-06-2015, 10:38 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-07-2015, 05:54 PM
RE: Restoring a Model 19 Code 126 - by Ron Ramirez - 03-07-2015, 06:35 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-07-2015, 11:19 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-07-2015, 11:23 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-08-2015, 03:37 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-09-2015, 11:16 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-10-2015, 08:16 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 04:01 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 06:25 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 07:25 PM
RE: Restoring a Model 19 Code 126 - by VE6ZRT - 03-11-2015, 07:33 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 07:53 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 08:45 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 10:06 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 10:24 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-12-2015, 04:11 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-14-2015, 08:58 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-14-2015, 09:41 AM
RE: Restoring a Model 19 Code 126 - by morzh - 03-14-2015, 10:52 AM
RE: Restoring a Model 19 Code 126 - by morzh - 03-14-2015, 10:59 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-15-2015, 06:05 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-15-2015, 07:42 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 02:13 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 08:46 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 11:11 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 11:32 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-21-2015, 05:45 PM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-21-2015, 07:20 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-22-2015, 09:45 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-22-2015, 09:52 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 09:23 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 09:24 AM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-24-2015, 09:46 AM
RE: Restoring a Model 19 Code 126 - by VE6ZRT - 03-24-2015, 12:26 PM
RE: Restoring a Model 19 Code 126 - by Mondial - 03-24-2015, 12:57 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 03:08 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 08:44 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-28-2015, 09:00 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-06-2015, 11:31 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-07-2015, 03:34 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-10-2015, 02:19 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-11-2015, 03:53 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-14-2015, 09:33 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-21-2015, 03:49 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-24-2015, 08:25 AM
RE: Restoring a Model 19 Code 126 - by Eliot Ness - 04-24-2015, 10:18 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-24-2015, 11:29 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 12-05-2015, 02:36 PM
Users browsing this thread: 24 Guest(s)
There are currently 6723 online users. [Complete List]
» 2 Member(s) | 6721 Guest(s)
