Need bakelite cabinet polishing tips
Hi Jim,
After so many hints for buffing Bakelite, I will add my 2 cents to the subject. The method I use is very simple, uses little if any tiresome hand rubbing, and turns out a better than factory finish. This method is a bit more expensive, but is reusable over and over again. I have found that Bakelite can be brought back to better that original brilliance by using cotton buffing wheels of various grades between course and soft. A motor driven arbor is used to drive the cotton buffing wheel. Sears sold arbors at one time, but I have not seen their catalog in a long time. Or, the free end shaft of a motor can be adapted to mount the buffing wheel. Buffing arbors (without a motor) can be found on Ebay or Google as: “buffing arbors” for an internet search. It is important that the arbor axle have bearings, have a v-pulley wheel on it, and be mounted on a cast iron stand. Double ended arbor buffing heads are available and provide for different grade buffers on each end or a wire wheel can be used on the other end. Power driven wheels must be anchored to something stout because some pressure will be put on the piece and the wheel can’t be allowed to move around. Most all buffing products are available on the internet and I have found Eastwood products have done well for me. A catalog is available at (Eastwood.com). There are numerous articles written on the precautions of avoiding disasters while buffing anything on a spinning wheel. Basically, a very firm grip on the piece to be buffed is absolutely necessary at all times without a moment or pause in attention to the task at hand. Just one lapse in attention and the piece will be thrown out of the hands in most any direction, usually crashing to the floor. Always buff in a direction that avoids edges. Buffing into an edge will cause the wheel to bite into the piece and attempt to grab it out of grasp. Eye protection, a mask, and gloves are necessary. I have found that the Bakelite case need not be washed and rinsed to get the grunge off before buffing, unless there is an unusual amount of dirt or oil/grease contamination. A small amount of plastic buffing compound is applied to the spinning wheel. The piece is brought to the wheel and using a light pressure the buffing action will start to clean and polish the Bakelite. The plastic compound will need to be replenished on the wheel as the polishing continues. When the wheel fills with dirty compound and crud, it will need to be cleaned and fluffed while turning with a buff rake. There is no method to tell when the job is complete and whether further buffing will produce a better result. But the buffing wheel must be kept clean. Your eye and judgment is the best method.
Need bakelite cabinet polishing tips - by Guest - 08-14-2008, 10:01 PM
[No subject] - by Chuck Schwark - 08-14-2008, 10:43 PM
Re: Need bakelite cabinet polishing tips - by Syl - 08-14-2008, 11:03 PM
[No subject] - by Guest - 08-16-2008, 03:21 PM
[No subject] - by Texasrocker - 08-17-2008, 12:47 AM
[No subject] - by Guest - 08-18-2008, 07:12 AM
Re: Need bakelite cabinet polishing tips - by Guest - 01-08-2009, 01:10 PM
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
There are currently 1559 online users. [Complete List]
» 1 Member(s) | 1558 Guest(s)
