Introduction and two Philcos
Thanks for all your help. I will definitely have a busy morning next Saturday. I'll replace the old capacitor blocks, the dogbone resistors, and check the antenna coil. Is there an easy way to tell the capacitance of those capacitor blocks? I assume a generic yellow capacitor will replace them with no problem. What will we do if the antenna coil is open?
Slave to an RCA Victor CTC-25
RE: Introduction and two Philcos - by morzh - 03-07-2015, 06:27 PM
RE: Introduction and two Philcos - by klondike98 - 03-07-2015, 06:53 PM
RE: Introduction and two Philcos - by morzh - 03-07-2015, 07:11 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-07-2015, 07:17 PM
RE: Introduction and two Philcos - by klondike98 - 03-07-2015, 08:15 PM
RE: Introduction and two Philcos - by morzh - 03-07-2015, 09:08 PM
RE: Introduction and two Philcos - by Mondial - 03-07-2015, 09:48 PM
RE: Introduction and two Philcos - by morzh - 03-07-2015, 10:04 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-07-2015, 10:11 PM
RE: Introduction and two Philcos - by morzh - 03-07-2015, 11:17 PM
RE: Introduction and two Philcos - by TheUniversalDave1 - 03-07-2015, 11:32 PM
RE: Introduction and two Philcos - by morzh - 03-08-2015, 12:18 AM
RE: Introduction and two Philcos - by Radioroslyn - 03-08-2015, 12:24 AM
RE: Introduction and two Philcos - by Joe Rossi - 03-08-2015, 08:17 AM
RE: Introduction and two Philcos - by Mondial - 03-08-2015, 09:30 AM
RE: Introduction and two Philcos - by klondike98 - 03-08-2015, 12:31 PM
RE: Introduction and two Philcos - by Mondial - 03-08-2015, 01:28 PM
RE: Introduction and two Philcos - by Mondial - 03-09-2015, 08:20 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-09-2015, 08:59 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-10-2015, 12:02 AM
RE: Introduction and two Philcos - by Radioroslyn - 03-10-2015, 12:26 AM
RE: Introduction and two Philcos - by Warren - 03-10-2015, 02:44 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-10-2015, 10:10 PM
RE: Introduction and two Philcos - by Mondial - 03-10-2015, 11:29 PM
RE: Introduction and two Philcos - by Warren - 03-11-2015, 02:43 PM
RE: Introduction and two Philcos - by Radioroslyn - 03-11-2015, 06:40 AM
RE: Introduction and two Philcos - by klondike98 - 03-12-2015, 08:37 PM
