Plate caps
Ive had good luck for yrs using JB Weld for this purpose. Make sure all the old adhesive is removed from glass, clean with alcohol, then the JB Weld makes a very secure bond between the metal & glass after full drying time of 24 hrs. JB Weld can be found at Walmart ( automotive dept),some Hardware, & most Auto Supply Stores. Great stuff!! Icon_wink
Plate caps - by Robert - 01-08-2009, 04:21 PM
Re: Plate caps - by Ron Ramirez - 01-08-2009, 07:00 PM
Re: Plate caps - by Texasrocker - 01-08-2009, 11:30 PM
Re: Plate caps - by planigan - 01-09-2009, 12:28 AM
Re: Plate caps - by Texasrocker - 01-14-2009, 01:04 AM
Re: Plate caps - by planigan - 01-14-2009, 01:59 PM
Re: Plate caps - by codefox1 - 01-14-2009, 03:14 PM
There are currently 10289 online users. [Complete List]
» 1 Member(s) | 10288 Guest(s)
