Wire wound resistor value
Quote:I have this broken resistor and need a value, it won't test but the body is brown, red paint on one end and a green dot in the middle.
http://www.nostalgiaair.org/PagesByModel...005364.pdf
Wire wound resistor value - by OldRestorer - 03-09-2015, 05:52 PM
RE: Wire wound resistor value - by Radioroslyn - 03-09-2015, 07:51 PM
RE: Wire wound resistor value - by Radioroslyn - 03-09-2015, 08:23 PM
RE: Wire wound resistor value - by OldRestorer - 03-09-2015, 09:03 PM
RE: Wire wound resistor value - by Radioroslyn - 03-09-2015, 09:25 PM
RE: Wire wound resistor value - by OldRestorer - 03-09-2015, 11:16 PM
RE: Wire wound resistor value - by Ron Ramirez - 03-10-2015, 09:12 AM
RE: Wire wound resistor value - by OldRestorer - 03-10-2015, 09:26 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
