Wire wound resistor value
No worries you can leave the 625 in there. The value isn't terribly critical, it set the bias for the output stage. Also better to be a little high than low in value. I saw a 625 ohm resistor in an other Fada schematic with a 43 in the audio output. But thought I would go with color code.
Wire wound resistor value - by OldRestorer - 03-09-2015, 05:52 PM
RE: Wire wound resistor value - by Radioroslyn - 03-09-2015, 07:51 PM
RE: Wire wound resistor value - by Radioroslyn - 03-09-2015, 08:23 PM
RE: Wire wound resistor value - by OldRestorer - 03-09-2015, 09:03 PM
RE: Wire wound resistor value - by Radioroslyn - 03-09-2015, 09:25 PM
RE: Wire wound resistor value - by OldRestorer - 03-09-2015, 11:16 PM
RE: Wire wound resistor value - by Ron Ramirez - 03-10-2015, 09:12 AM
RE: Wire wound resistor value - by OldRestorer - 03-10-2015, 09:26 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6133 online users. [Complete List]
» 1 Member(s) | 6132 Guest(s)
