38 116 tuner rebuild
Don't scrape the residue from the groove in the shaft. It is an insulating layer which isolates the brass sliver from the muting contact. The sliver is just a shim to take up play in the shaft bearing. If you scrape off the insulation you will ground out the muting contact and short out the audio.
38 116 tuner rebuild - by SteveJB - 03-09-2015, 08:59 PM
RE: 38 116 tuner rebuild - by morzh - 03-09-2015, 09:18 PM
RE: 38 116 tuner rebuild - by Mondial - 03-09-2015, 09:37 PM
RE: 38 116 tuner rebuild - by SteveJB - 03-10-2015, 01:05 AM
